RFEM Server gRPC API | Crash
Hello Dlubal Community,
our RFEMServer instance running on a Windows Server experiences crashes quite often. From the logs, it is apparent that the crash is related to the CrashReportEngine, but the details are not understandable for a layman like me.
Here is an excerpt from the logs:
2026/03/02 14:10:02 670399	GRPC [gRPCApplicationServer.cpp->wsgrpc::AuthenticationProcessor::Process:122]	API Client Info: C# | 2.12.9.0
2026/03/02 14:10:02 670707	GRPC [GrpcSession.cpp->wsgrpc::GrpcSession::logMethodStart:131]	RPC method invoked: close_model
2026/03/02 14:10:02 910857	INFO [FemBaseWrapper.cpp->rfemsolver::FemBaseWrapper::deleteSectionFiles:2920]	FemBaseWrapper::deleteSectionFiles - Start
2026/03/02 14:10:02 911229	INFO [FemBaseWrapper.cpp->rfemsolver::FemBaseWrapper::deleteSectionFiles:2922]	FemBaseWrapper::deleteSectionFiles - End
2026/03/02 14:10:02 991645	GRPC [gRPCApplicationServer.cpp->wsgrpc::AuthenticationProcessor::Process:122]	API Client Info: C# | 2.12.9.0
2026/03/02 14:10:03 532968	GRPC [GrpcSession.cpp->wsgrpc::GrpcSession::logMethodStart:131]	RPC method invoked: close_connection
2026/03/02 14:10:03 533112	GRPC [gRPCApplicationServer.cpp->wsgrpc::gRPCApplicationServer::closeSession:1080]	Application is unlocked
2026/03/02 14:10:03 534223	GRPC [gRPCApplicationServer.cpp->wsgrpc::AuthenticationProcessor::Process:122]	API Client Info: C# | 2.12.9.0
2026/03/02 14:10:03 601365	GRPC [ApiSessionJsonFileLogSink.cpp->wsgrpc::ApiSessionJsonFileLogSink::createApiSessionLogFiles:54]	Log files for API Session '6ce198aa-7d8e-4d77-9ecc-518b3c274fb8' were created
2026/03/02 14:10:03 601423	GRPC [GrpcSession.cpp->wsgrpc::GrpcSession::createSession:87]	API session '6ce198aa-7d8e-4d77-9ecc-518b3c274fb8' was created
2026/03/02 14:10:03 601818	GRPC [GrpcSession.cpp->wsgrpc::GrpcSession::logMethodStart:131]	RPC method invoked: close_connection
2026/03/02 14:10:03 602071	GRPC [gRPCApplicationServer.cpp->wsgrpc::gRPCApplicationServer::closeSession:1080]	Application is unlocked
2026/03/02 14:10:03 906124	GRPC [GrpcSession.cpp->wsgrpc::GrpcSession::closeSessionAndUploadApiCalls:253]	API session '6ce198aa-7d8e-4d77-9ecc-518b3c274fb8' was closed
2026/03/02 14:10:04 095646	INFO [FileUploader.cpp->utilities::FileUploader::uploadFinished:143]	File 'api-logs_6ce198aa-7d8e-4d77-9ecc-518b3c274fb8_1772457003894.zip' uploaded successfully
2026/03/02 14:10:05 558909	ASSERT [debugAsserts.cpp->base::debug::defaultAssertHandler:266]	Assertion failed!
file: D:\R20-apps\bin_release\Base\../../src/Base/CrashReportEngine.cpp
line: 519
Assert condition: Application is going to crash. Crash report will follow...
StackTrace:
 0# base::debug::ignoreAllAsserts in Base
 1# base::debug::getStackTraceFrames in Base
 2# base::debug::getStrippedStackTraceFrames in Base
 3# base::debug::getStrippedStackTrace in Base
 4# base::debug::dynamicStringAssert in Base
 5# base::CrashReportEngine::vectoredExceptionHandler in Base
 6# RtlpCallVectoredHandlers in ntdll
 7# RtlDispatchException in ntdll
 8# KiUserExceptionDispatch in ntdll
 9# QDateTime::operator= in Qt5Core
10# 0x00007FF9DAE29339 in RxWebServicesGrpc
11# 0x00007FF9DAE86CCE in RxWebServicesGrpc
12# 0x00007FF9DAE4D729 in RxWebServicesGrpc
13# 0x00007FF9DA91FBBD in RxWebServicesGrpc
14# 0x00007FF9DA91B6EE in RxWebServicesGrpc
15# 0x00007FF9DA915FD6 in RxWebServicesGrpc
16# 0x00007FF9DA91D7B9 in RxWebServicesGrpc
17# qt_plugin_query_metadata in RxWebServicesGrpc
18# 0x00007FF9DA91CC66 in RxWebServicesGrpc
19# 0x00007FF9DAE4D870 in RxWebServicesGrpc
20# qt_plugin_query_metadata in RxWebServicesGrpc
21# qt_plugin_query_metadata in RxWebServicesGrpc
22# qt_plugin_query_metadata in RxWebServicesGrpc
23# qt_plugin_query_metadata in RxWebServicesGrpc
24# qt_plugin_query_metadata in RxWebServicesGrpc
25# BaseThreadInitThunk in KERNEL32
26# RtlUserThreadStart in ntdll
Assert id:1
Assert dynamic id:{52839fc8-3602-4887-b5c4-ae9a6cbcc8dc}
Error trying to send crash report: - 'The file 'E:/RfemTemp/RFEM6_6.12/logs/api_logs/api-requests_6ce198aa-7d8e-4d77-9ecc-518b3c274fb8.log' does not exist.<br>The file 'E:/RfemTemp/RFEM6_6.12/logs/api_logs/api-session_6ce198aa-7d8e-4d77-9ecc-518b3c274fb8.log' does not exist.'
CRASH_REPORT_WAS_NOT_SENT
I could not find any entry regarding this in the RFEM Release Notes, so I assume the error still exists and an update of RFEM does not make sense yet.
I am happy to provide the complete logs if needed.
Info
RFEM version: 6.12.0009
Dlubal.Api version: 6.12.9
Hi hasslernils,
I would try the latest version, even if there was no related fix documented in the release notes. If this doesn't help it would be good to have the complete logs.
Thank you.
