RFEM6 calculate_specific() error
Environment:
  • RFEM: 6.10.0012
  • dlubal.api Python package: 2.12.10 (latest available, built for 6.10.0011)
Issue:
When using calculate_specific() or get_result_table() with RFEM.OBJECT_TYPE_LOAD_COMBINATION, the server rejects the request with "Only loading types are allowed".
My code is
from dlubal.api import rfem
# Build list of ObjectId for load combinations
loading = []
for rng in [(10, 17), (20, 27), (30, 37), (40, 47)]:
    loading.extend([
        rfem.ObjectId(no=i, object_type=rfem.OBJECT_TYPE_LOAD_COMBINATION)
        for i in range(rng[0], rng[1] + 1)
# Run selective calculation
rfem_app.calculate_specific(
    loadings=loading,
    skip_warnings=True
My error is
2025-12-28 22:53:29 [WARNING] infrastructure.rfem_api.foundation.rfem6_foundation - Selective calculation failed. Error: <_InactiveRpcError of RPC that terminated with:
        status = StatusCode.INVALID_ARGUMENT
        details = "Only loading types are allowed."
        debug_error_string = "UNKNOWN:Error received from peer  {grpc_message:"Only loading types are allowed.", grpc_status:3, created_time:"2025-12-28T15:53:29.525489+00:00"}"
>. Attempted loadings: 32 items. Falling back to calculate_all.
Analysis:
I investigated by checking the enum values and logging what object_type my ObjectIds actually have:
# Debugging code to check values
# Check the constant value
print(f"OBJECT_TYPE_LOAD_COMBINATION = {rfem.OBJECT_TYPE_LOAD_COMBINATION}")
# Output: 161
# Create ObjectId and check what it contains
oid = rfem.ObjectId(no=10, object_type=rfem.OBJECT_TYPE_LOAD_COMBINATION)
print(f"ObjectId object_type = {int(oid.object_type)}")
# Output: 163 (!)
Expected: rfem.OBJECT_TYPE_LOAD_COMBINATION should be 161
Actual: The ObjectId ends up with object_type=163
Checking what 163 corresponds to:
print(f"OBJECT_TYPE_LOAD_COMBINATION = {rfem.OBJECT_TYPE_LOAD_COMBINATION}")  # 161
print(f"OBJECT_TYPE_STATIC_ANALYSIS_SETTINGS = {rfem.OBJECT_TYPE_STATIC_ANALYSIS_SETTINGS}")  # 163
So the ObjectId is being created with type 163 (OBJECT_TYPE_STATIC_ANALYSIS_SETTINGS) instead of 161 (OBJECT_TYPE_LOAD_COMBINATION), which the server correctly rejects as "not a loading type".
Am I doing something wrong? or is it a bug? or is it because of the mismatch between the python version and the RFEM6 version and will be solved when the next package update comes?
Thanks,
Samuel
Upon further consideration I don’t think the mismatch is the issue has I had the rror in 6.12.0010 (and i had the matching python dlubal.api). I upgraded to 6.12.0012 to see if that fixed the issue but it was still there.
Hi Samuel,
this type of issue is really related to different version between client and server.
Since client 2.12.12 has been already released, can you try it with RFEM 6.12.0012?
Hopefully it will work.
Regards
Yes thank you, being on the same version fixed it :slight_smile:
