Embed rods in beam slab and connect with sheathing
I am currently modeling a timber panel wall with a large opening. According to Colling and Janßen (Bracing of Timber Panel Buildings), I need ribs at the height of the lintel, horizontal distribution ribs, so that I can account for the panels above and below the opening and, unlike in the Eurocode, consider the entire wall.
To verify my manual calculation, I would like to model it exactly the same way. I have inserted a beam member at the height of the lintel, integrated the corresponding lines into the surface, and now want to connect this with the sheathing (rigid coupling). Unfortunately, various error messages keep appearing about intersecting points and lines and finally "The projection line is not integrated into the surface."
Can anyone help me with this, or does this function (still?) not exist?
Thanks a lot in advance and best regards
Valentin
Hi Valle_S,
Thank you for your message!
:right_arrow: Click on File → Save As and choose the following settings to reduce the file size:
:owl: Don't want to share the file publicly? No problem – send it to me via direct message: click on my profile picture or my username → Message.
Please feel free to provide me with the model including the problem-causing lines so that I can better understand your approach to modeling.
Maximilian Wittmann
Hello Maximilian,
attached is the file.
IW 01-1 - Kopie.rf6 (2.1 MB)
Hi Valle_S,
I took a look at your model. :face_with_monocle:
I noticed that the lines of the reinforcement beam you created, which lie within the sheathing areas, are not integrated into these areas. For example, line 777 is not integrated into area 28. This can also be seen by double-clicking on the area → tab "Integrated." The corresponding line numbers are missing here. I also noticed that automatic object detection is disabled in this window. Did you make this setting, and if so, for what reason? :thinking:
Max
