Stability of Cross-Laminated Timber Structures
I’m using RFEM 6 and add-on for CLT structures. I know that this add-on does not calculate stability (buckling) directly. Which options do we have to check buckling of walls within the model? The same goes for fire combinations which are a lot of times critical.
Hello Wolfram,
the easiest way is to determine the eigenmode with the structural stability and then apply it as an imperfection. The internal forces according to second-order theory as well as the applied imperfection include the stability check for the stress verification. You can find more information here:
Thank you. That means I need the Structure Stability add-on? Could I manually input imperfection and then check the stresses after 2nd order theory analysis?
Alternatively you can use equivalent loads or create a load case and apply loads to get the buckling shape. For latest you can then take this deformation shape and assign the imperfection:
