Duplicate steel connections using API
Is there a way to duplicate steel connections or add components using the API II?
The following code copies most settings, except for the bearing conditions of the rods, but the actual components of a connection are not transferred.
from dlubal.api import rfem
source_joint_index: int = 1
target_joint_index: int = 2
    source_joint: rfem.steel_joints_objects.SteelJoint = rfem_app.get_object(
        obj=rfem.steel_joints_objects.SteelJoint(
            no=source_joint_index,
    target_joint: rfem.steel_joints_objects.SteelJoint = (
        rfem.steel_joints_objects.SteelJoint()
    target_joint.CopyFrom(source_joint)
    target_joint.no = target_joint_index
    target_joint.name = "target_joint"
    rfem_app.create_object(target_joint)
20260502_Anfrage_Anschluss_duplizieren.rf6 (1.1 MB)
Hi Benedikt,
The components of the steel connections use a special identification format that consists of a unique database GUID and an object tag (e.g., "GUID|Flange1").
The problem: These IDs are bound:
  • If you copy the ID, the server refuses creation due to an identity conflict with the original object.
  • If you delete the ID to generate a new one, the component loses its internal reference to the rod geometry, as the API currently does not provide a mechanism to automatically reassign these "floating" components to the new node.
For safety, the server therefore discards the components instead of creating a potentially unstable object.
At the moment, you could copy the steel connection but would then have to recreate the components.
Rebecca Göbel
