πŸ“₯ Steel Purlin Connections
Check out these RFEM models to enhance your skills and:
Steel purlin connections are essential structural details used to transfer loads between purlins and the supporting roof structure. They typically consist of bolted or welded steel components such as plates, brackets, angles, or end connections.
Depending on the structural system and connection type, they can be designed for various loading, fabrication, and installation requirements.
Find 3D Models
