Stress readout: +/- signs API vs RFEM
I am working with the RFEM API in Visual Studio Code and am trying to retrieve the different stress components. I would like to retrieve σx+, but this does not appear to be available as a separate option. Therefore, I am using the basic stress results at the bottom, middle and top of the surface.
I noticed that the values in the generated tables differ depending on the orientation of the local coordinate system defined in the base data. When the z-axis is oriented downward, the results correspond correctly to the values shown in RFEM. However, when the z-axis is oriented upward, the values generated by the API do not correspond to the results displayed in RFEM.
I have prepared a file containing several comparisons.
In conclusion, my question is: Is there an issue with the API when generating these tables, or am I interpreting the results incorrectly?
Comparison different axes systems.pdf (1.5 MB)
Thanks! Kind regards Bart
Hi BartR,
welcome to the Community!
Did you ensure, that you compare the same values (grid vs. FE results)?
Hi Stefan,
Yes, I compared the same values. It looks like the table from the API flips the bottom and top rows or something like that. Or i totally misunderstand something.
Hi BartR,
thanks for your response!
:right_arrow: Click on File → Save as and choose the following settings to reduce the file size:
:owl: Prefer not to share the file publicly? No problem – send it to me via direct message: click on my profile picture or user name → Message.
Question_API_stress_readout.rf6 (1.0 MB)
It is just a file for testing.
Hi BartR,
I will check the issue with the layered results. In the meantime, as this was your initial wish. You should be able to get also sigma_x_plus results:
from dlubal.api import rfem, common
    result_table:common.Table = rfem_app.get_result_table(
        table = rfem.results.ResultTable.STATIC_ANALYSIS_SURFACES_BASIC_STRESSES_MESH_NODES_TABLE,
        loading= rfem.ObjectId(
            no=1,
            object_type=rfem.OBJECT_TYPE_LOAD_CASE
    print(f"\nResult Table:\n{result_table.data}"),
Hi BartR,
RFEM 6.15.0013 is supposed to include the fix regarding TOP/ BOTTOM stresses as well.
