Tekla Export to RFEM issue
I tried to export a simple model from Tekla using the Export to RFEM plugin. I managed to export the model to RFEM but the member length in RFEM ended up being 1/10 of the length in Tekla.
How can I correct this?
Hello Simca,
Thank you for your question!
I did some tests with different unit settings in RFEM and Tekla and could not reproduce this problem.
To analyse the problem more precisely, the tekla file would be very helpful.
Can you share your file here or send it to me via direct message: click on my profile picture or user name → *Message*
It'd be great to have the following info as well:
What Tekla Version do you use?
Are you using any specific environments in Tekla?
Paul Sivolgin
