Trapezoidal sheet as bracing in a wall
Hi, I am investigating a steel tower as part of my bachelor's thesis. In this context, I want to model a trapezoidal sheet as a stiffening wall in my frame. The trapezoidal sheet should be fully welded between the columns (vertical) and the beams (horizontal) (like in a container).
I have already created the trapezoidal sheet by modeling it as a bar and converting it into a surface.
My question now is how to sensibly connect the trapezoidal sheet with the columns and beams so that it resembles a weld seam, or if there are more effective methods for creating the trapezoidal sheet?
Trapezoidal sheet as wall cladding.rf6 (1.7 MB)
Hi Tk259 :blush:
Thank you very much for your inquiry!
You can connect the sheet metal to the supports and beams using node couplings.
Feel free to take a look at the following entries:
• :blue_book: Online manual – Node couplings in RFEM 6
https://www.dlubal.com/de/downloads-und-infos/dokumente/online-handbuecher/rfem-6/005986#mainTab
• :red_question_mark: FAQ 005749 – Application of node couplings
https://www.dlubal.com/de/support-und-schulungen/support/faq/005749
Alternatively, modeling as an orthotropic surface would also be conceivable:
• :red_question_mark: FAQ 002468 – Orthotropic surfaces
https://www.dlubal.com/de/support-und-schulungen/support/faq/002468
I hope this helps you further!
If you have any questions or anything is unclear, feel free to contact me anytime :+1:
Sandy Matula
