Is there a possibility in RFEM6 to compare two structural models (two RFEM6 files) and display differences in cross-sections, for example, as visibility?
My current workflow:
Export the table of members from both versions to Excel and compare the tables + create a member list of the "differences" using, for example, Copilot.
I then have to manually create the member list as an object selection.
Scenario: Continuation of planning and revision of existing models.
Hello Flo6000,
such an option does not currently exist. I will include your request as a desired feature.
Basically, your project can be realized via the API. With it, you can query all objects with their properties and then do whatever you want with the data or "write back" the different objects.
Hello Gerhard,
thank you for your quick response.
Unfortunately, the API is no longer available for free. So I'll take the route via the Excel interface.
It would be great if you could offer something there in the future. Revisions are everyday business for us structural engineers.
Flo
