Moving Load on Curved Surfaces
As part of my master's thesis, I need to model a person walking on a bridge.
For this, I have a model of the bridge in RFEM 5.
I have tried to model the moving load using the RF-BEWEG Surfaces add-on module. This works on a flat surface.
However, the bridge has a camber, so I need to model the moving load on a curved surface. I tried to assign a curved surface in the RF-BEWEG Surfaces module, but this does not work.
Can you help me if there is another trick to model the moving load on a curved surface?
Screenshot 2025-12-10 154829
Hi MoRe19,
Thank you for your message!
The live loads should also work on curved surfaces. I have just successfully tested this myself.
:right_arrow: Click on File → Save As and choose the following settings to reduce the file size:
:owl: Don’t want to share the file publicly? No problem – send it to me via direct message: click on my profile picture or my username → Message.
Sandy
Please note the following points to ensure that moving loads can be applied correctly:
• Moving loads cannot be applied on spline surfaces or on surfaces with a thickness of zero.
• Instead, use quadrangular surfaces with the standard stiffness.
Also important:
• The lines must be integrated into the surface so that loads can be applied to them.
If you keep this in mind, applying the moving load should work without any problems. :blush:
Hello Sandy,
thank you for the help. However, the surface must not have any influence on the behavior of the model.
If I set the stiffness of the surface to standard, I have to assign a material to the surface, and then it does have an influence.
Is there a way to model the surface without it having any influence?
If the surface should have no influence on the load-bearing behavior of the model, then the only option is indeed a modeling with negligible stiffness.:+1:
Possible procedure:
  1. Surface type
    • Quadrangle/ Standard
  2. Material
    • Create a custom "user-defined material"
  3. E-modulus
    • Strongly reduce the modulus of elasticity so that the stiffness is almost negligible
  4. Thickness
    • Define a very small thickness
In this way, the surface remains present and evaluable in the model without significantly affecting the global load-bearing behavior.
All right. I have defined the area based on the specifications. However, the Rf-Movement Areas module cannot generate load cases.
Screenshot 2026-03-18 100001
I cannot integrate the lines into the area because they are already the boundary lines.
Screenshot 2026-03-18 100614
Hi MoRe19,
Thank you for your feedback!
To analyze the problem more precisely, the model file would be very helpful once again.
Sandy Matula
Thank you very much for the model file! :blush:
Please note that boundary lines do not need to be integrated into the surface.
Regarding RF-BEWEG:
• Due to the existing eccentricities, no load cases can be generated.
• The cause is probably the curved surface.
:backhand_index_pointing_right: Here you would need to consider an alternative approach.
I tried to use an alternative approach without eccentricity. However, now a different error occurs when I try to define the line sets
Screenshot 2026-03-18 160505
Unfortunately, I don't have a concrete idea for an alternative approach, but this variant does not seem to work.
The message appears when no loads can be generated with the inputs made.
:backhand_index_pointing_right: Please carefully check your inputs again.
Hi :blush:
you are already getting an error message when calculating the self-weight load case. Therefore, you should first check your modeling.
Most likely, the problem is due to too small a surface thickness.
:backhand_index_pointing_right: Suggestion for solution:
Increase the thickness of the affected surface slightly
The calculation should then be possible to perform👍
