🚀 X.13.0009 – Updates to RFEM, RSTAB, RSECTION, and Dlubal API
Exciting Update from Dlubal Software: Version X.13.0009 of RFEM 6, RSTAB 9, and RSECTION 1 is available now!
Download the latest enhancements and bug fixes to boost your productivity from the Dlubal Extranet and review all improvements in the Release Notes.
:information_source: To upgrade from version X.12.XXXX, an active Service Contract is required.
:information_source: The Dlubal API is updated 1–2 days later.[1]
Do you have questions or need assistance? Feel free to reach out – we're happy to help :slightly_smiling_face:
  1. API Release Notes ↩︎
When I extract the MSI using RFEM_6.13.0009.exe /E and run Dlubal_RFEM_64bit.msi /quiet, a restart occurs at the end of the installation on my system. This has not happened with previous versions so far. Is it possible that the latest version has a reboot requirement set by default? Does Dlubal_RFEM_64bit.msi /quiet /norestart work?
Hello Lucas,
Welcome to our community.
Nothing has been changed in the installation. A restart is not performed by default after the installation.
A restart is only performed if a component could not be replaced during the installation. This is the case, for example, if RFEM is still open during the installation.
Yes, it is possible to use msiexec -i Dlubal_RFEM_64bit.msi -quiet -norestart. However, this is actually not necessary.
The sub-case feature sounds interesting. Any documentation available yet?
