Modeling time course analysis for glass facade
Does anyone have experience with time history analysis?
I created the model with a post-and-beam construction and glass panes that are connected to the post-and-beam via spring supports.
Symmetry conditions were specified at the bar ends of the beams.
Two loads were applied at the edges of the panes using a sinusoidal function.
Screenshot 2026-02-16 133506
Screenshot 2026-02-16 133403
Hi HansiG,
I have done quite some Time History Analysis within RFEM 6. It looks like you have zero results within your Time History Analysis. Please check on your Loading (examplic the direction) and Time Diagram input. You could also test a very high load magnitude just for forcing some results.
Thomas Eichner
Hi HansiG,
I inspected the model. You did only place loads in your static Loadcase 1.
Your Time History Loadcase does not contain any loads.
Either you place loads also inside your Time History Loadcase, or you do use a Loadcombination to combine Loads from other Loadcases with Time Diagrams.
When placing loads within the Time History LC 3, you will receive results:
Thomas Eichner
Hello Thomas,
Thanks already for your help.
At the bottom right of your screenshot, it still shows a few warning messages, do you know what that is about? It shows the same ones for me as well.
Hannes
